wwleone 1,768 Posted May 19, 2018 Report Share Posted May 19, 2018 ORIGINALE MINI f55 f56 f57 umrüstsatz Fanali Luci Posteriori LCI Union Jack https://www.ebay.it/itm/Original-MINI-F55-F56-F57-Umrüstsatz-Heckleuchten-Rückleuchten-LCI-UNION-JACK/382466275478?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649 Serve codifica ! ! ! Link to post Share on other sites
mrJCW 7 Posted May 19, 2018 Report Share Posted May 19, 2018 356 Euro circa https://www.lohen.co.uk/mini-union-jack-rear-tail-lights-for-f56-f55 Link to post Share on other sites
fulvix 11 Posted May 24, 2018 Report Share Posted May 24, 2018 356 Euro circa https://www.lohen.co.uk/mini-union-jack-rear-tail-lights-for-f56-f55 Ci sono anche per F60?Inviato dal mio iPhone utilizzando Tapatalk Link to post Share on other sites
wwleone 1,768 Posted May 24, 2018 Author Report Share Posted May 24, 2018 59 minuti fa, fulvix ha scritto: Ci sono anche per F60? Inviato dal mio iPhone utilizzando Tapatalk Per ora no, forse in futuro. Link to post Share on other sites
fulvix 11 Posted May 24, 2018 Report Share Posted May 24, 2018 Per ora no, forse in futuro.Inviato dal mio iPhone utilizzando Tapatalk Link to post Share on other sites
Tommaso13 0 Posted November 4, 2018 Report Share Posted November 4, 2018 Il 19/5/2018 Alle 08:54, wwleone ha scritto: ORIGINALE MINI f55 f56 f57 umrüstsatz Fanali Luci Posteriori LCI Union Jack https://www.ebay.it/itm/Original-MINI-F55-F56-F57-Umrüstsatz-Heckleuchten-Rückleuchten-LCI-UNION-JACK/382466275478?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649 Serve codifica ! ! ! Te li hai montati ? Link to post Share on other sites
wwleone 1,768 Posted November 4, 2018 Author Report Share Posted November 4, 2018 1 ora fa, Tommaso13 ha scritto: Te li hai montati ? No, a me piacciono ma a mio figlio (che usa prevalentemente la JCW) NO ! ! ! Link to post Share on other sites
wwleone 1,768 Posted April 27, 2019 Author Report Share Posted April 27, 2019 VARIANTE BLACK & WHITE https://www.ebay.it/itm/333172216725?ul_noapp=true Link to post Share on other sites
TonyFlow 0 Posted May 4, 2019 Report Share Posted May 4, 2019 (edited) Ciao... ho una one con i fari non a led, se volessi montare questa ultima variante black & white potrei farlo senza problemi che tu sappia? e in merito alla codifica...dici che conviene portarla alla bmw o é un lavoro fattibile da qualsiasi elettrauto? E soprattutto il prodotto pensi sia affidabile? Edited May 4, 2019 by TonyFlow Link to post Share on other sites
krismini.155 113 Posted May 4, 2019 Report Share Posted May 4, 2019 il problema è che se non hai i fari a led il connettore per il faro va cambiato, a quanto pare oltre poi a fare la codifica che puoi fare anche te tramite obd2 e un programma , anche da cel Link to post Share on other sites
MF4 229 Posted May 4, 2019 Report Share Posted May 4, 2019 Per coloro che non hanno l'opzione fari a led, sì bisogna cambiare qualche cablaggio e poi codificare il tutto. La codifica si può fare tramite esys (se avete le ultime versioni con il relativo launcher) oppure con BimmerCode e relativo adattatore. Vi allego un file ufficiale bmw dove viene spiegato come cambiare i cablaggi purtroppo è in tedesco ☹️ EBA Union Jack.pdf Link to post Share on other sites
TonyFlow 0 Posted May 4, 2019 Report Share Posted May 4, 2019 Fattibile quindi in concessionaria? Il prodotto non é originale giusto...credete sia valido? Link to post Share on other sites
krismini.155 113 Posted May 5, 2019 Report Share Posted May 5, 2019 Per coloro che non hanno l'opzione fari a led, sì bisogna cambiare qualche cablaggio e poi codificare il tutto. La codifica si può fare tramite esys (se avete le ultime versioni con il relativo launcher) oppure con BimmerCode e relativo adattatore. Vi allego un file ufficiale bmw dove viene spiegato come cambiare i cablaggi purtroppo è in tedesco EBA Union Jack.pdf Che tipo di adattatore serve? Inviato dal mio iPhone utilizzando Tapatalk Link to post Share on other sites
MF4 229 Posted May 5, 2019 Report Share Posted May 5, 2019 1 ora fa, krismini.155 ha scritto: Che tipo di adattatore serve? Inviato dal mio iPhone utilizzando Tapatalk Io utilizzo il Vgate modello iCar pro bt 4.0 1 Link to post Share on other sites
krismini.155 113 Posted May 5, 2019 Report Share Posted May 5, 2019 Io utilizzo il Vgate modello iCar pro bt 4.0Ok pensa ci volesse del altroInviato dal mio iPhone utilizzando Tapatalk Link to post Share on other sites
TonyFlow 0 Posted June 21, 2019 Report Share Posted June 21, 2019 (edited) Quindi oltre i fari ovviamente occorre acquistare L adattatore di cui sopra e codifica tramite app? Come rimedio i codici? I cablaggi li farò fare in conce? Edited June 21, 2019 by TonyFlow Link to post Share on other sites
Lance91 5 Posted June 24, 2019 Report Share Posted June 24, 2019 Il 5/5/2019 Alle 11:36, MF4 ha scritto: Io utilizzo il Vgate modello iCar pro bt 4.0 Io ho la versione WiFi e va comunque bene con BC, bisogna solo settare bene il WiFi dello smartphone per evitare disconnessioni. Link to post Share on other sites
MF4 229 Posted June 24, 2019 Report Share Posted June 24, 2019 16 minuti fa, Lance91 ha scritto: Io ho la versione WiFi e va comunque bene con BC, bisogna solo settare bene il WiFi dello smartphone per evitare disconnessioni. Si certo, per la versione BT è importante mettere il telefono in modalità volo e poi attivare il Bluetooth. Questo serve per evitare che nella fase di codifica si riceva una chiamata, un messaggio che possa interrompere il processo di codifica, è una precauzione importante. Link to post Share on other sites
Corradodg89 0 Posted January 3, 2020 Report Share Posted January 3, 2020 Buonasera.. Ma i fari union Jack comprarli alla concessionaria quanto costerebbero? Link to post Share on other sites
MF4 229 Posted January 3, 2020 Report Share Posted January 3, 2020 10 minuti fa, Corradodg89 ha scritto: Buonasera.. Ma i fari union Jack comprarli alla concessionaria quanto costerebbero? Io li ho presi prima di Natale e costavano 315 euro ivati, poi con lo sconto tessera del 30% mi sono costati 220,50 euro Link to post Share on other sites
LucasCooper 981 Posted January 3, 2020 Report Share Posted January 3, 2020 Confermo i 220 euro con lo sconto federclub (da confermare ancora per il 2020), uno dei primi upgrade che ho fatto sulla F56 😀 Link to post Share on other sites
wwleone 1,768 Posted January 3, 2020 Author Report Share Posted January 3, 2020 https://www.ebay.it/itm/MINI-F55-F56-F57-ORIGINALI-Coppia-Luci-Fari-posteriori-UNION-JACK-RIBASSO/223777088344?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649 € 229.99+20 ma non conosco il venditore (sembra 1 concessionario MINI siciliano) Link to post Share on other sites
Ste_911 0 Posted January 8, 2020 Report Share Posted January 8, 2020 Anche io vorrei mettere i nuovi fari posteriori, confermo che costano 220 in BMW, mi frena solo il costo del montaggio...Mi dicono 2 ore di manodopera... Confermate?Grazie! Link to post Share on other sites
krismini.155 113 Posted January 8, 2020 Report Share Posted January 8, 2020 Secondo me fai prima a montarlo da solo ci vuole 20 minuti... per la codifica io con bimmercode non ho avuto problemi ... è molto facile ... ci sono dei video su YouTube per effettuare la procedura... l’app costa 30€ Inviato dal mio iPhone utilizzando Tapatalk Link to post Share on other sites
krismini.155 113 Posted January 8, 2020 Report Share Posted January 8, 2020 P.s 2 ore di manodopera a 60€ + iva sono più di 140 €Inviato dal mio iPhone utilizzando Tapatalk Link to post Share on other sites
Recommended Posts
